Doing a frame off on a 69 350/350 and starting to reassemble chassis components. The TIM&JG does not mention the brake pads. Questions are 1) What was the finish on the steel backing plate? 2) Pads were riveted? and 3) Did the original pads have the stainless steel anti-rattle shims that come with current pads? Thanks for any information. Steve
1969 Brake Pads
Re: 1969 Brake Pads
Steve, the front backing plates were a dull zinc. as far as the pads go, They are really not a judged item and would tell you just install a quality set to keep away the squealing brakes. the original pad did not have a shim on the back of pads and were a organic type pad. and would tell you that a shim on the pad will modernize the pads and help with squeeling brakes. ceramic disc pads are a low dusting pad, and a semi metallic or metallic pad will leave dust on your wheels and sometimes cause noise. Go with what works better and quieter.New England chapter member, 63 Convert. 327/340- Chapter/Regional/national Top Flight, 72 coupe- chapter and regional Top Flight.- Top
Re: 1969 Brake Pads
Steve -- according to the 1969-era GM parts books, the service pads would be #5452513, which are those shown with the rivets, and I'll guess that production was as well. The others in the pics are for the HD brakes (J56 fronts).Doing a frame off on a 69 350/350 and starting to reassemble chassis components. The TIM&JG does not mention the brake pads. Questions are 1) What was the finish on the steel backing plate? 2) Pads were riveted? and 3) Did the original pads have the stainless steel anti-rattle shims that come with current pads? Thanks for any information. Steve
J56-513-2621609 (Custom).jpgJ56-asb-org (Custom).jpgJ56 vs Std-3.JPG- Top
