My '67 L79 carburetor is a holley and has no external sight plugs to view fuel level and no external needle and seat that can be adjusted like the carb on my '66 L72. There are two circular plugs of about 1/2" to 5/8" in diameter, one on the primary side and one on the secondary side. The one on the primary side is allowing fuel to seep out through the top of this plug as the engine is running. The one on the secondary side is dry. The exhaust smell leads me to think that the engine is running extremely rich and adjusting the idle mixture screws does nothing to affect this condition. Is this configuration correct for a '67 L79 holley carburetor and, if so, is the only way to set the float level through an internal adjustment which would require disassembly of the carb? There is no visible fuel dripping into the carb as the engine is running and both sides of the throttle plates are dry as well with the engine running. Any replies would be most appreciated. Thanks and have a safe and happy Memorial Day and thank you for your sacrifices to all of those who served and are being though of and remembered today!
Joe
Joe
