C2 P/B push rod - NCRS Discussion Boards
C2 P/B push rod
  • Jim S.
    • March 1, 1986
    • 1392
    C2 P/B push rod
    Should you lube the rubber o ring that goes around the inside / booster side / of the push rod ?
    Or any other part of it for that matter ?
  • Jim S.
    • March 1, 1986
    • 1392
    Re: C2 P/B push rod
    Somebody here must know ! Somebody here knows everything !
    I called three brake shops . I got three answers. "Light lube" , "No lube" and "Don't know " .
    Thanks ,
    Jim
      • 6940
      Re: C2 P/B push rod
      Jim, the Factory never used any lube, But I would used a light coating of Dielectric Grease on the o-ring and a dab of White lube on the end of shaft, anything that has contact surface won't hurt. and the O-ring install with the light coating of dielectric will help on install, and will have no effect on O-ring and may help from cutting the O-ring when installing shaft.
      • Jim S.
        • March 1, 1986
        • 1392
        Re: C2 P/B push rod
        "the Factory never used any lube "
        Thanks Edward,
        That is what I wanted to know . I read the service manuals , and they never mentioned a lube on reinstall , but it made sense to me to do it . So I was curious as to what was correct , and what was practiced ?
        Jim
          • 6940
          Re: C2 P/B push rod
          Jim, boosters where likely assembled by machines in mass Quantitys. Being in the auto trade i have had many master cylinders off GM cars through the 40+ years and have never seen any lube on the shaft tips, But anything to help a moving part move easier, or slide to assemble makes sense.
