I bought engine mounts from one of the vette suppliers. They were the ones that were not safe. I was going to install the safety cable but found that when I installed the correct fan it was way to low and will hit the shroud on the bottom. I removed the mounts to install the required shims and found that it was about 1/4" lower than a safety mount I decided to use. The safety replacement mount and shim would put the fan where it needed to be.
The problem now is that the safety mounts are to narrow to fit over the frame receiver where the bolt go's thru. I measured the safety mount against the original style and it is 1/8" narrower. I then measured where the mount fits on the frame and it is 1/8" larger than the mount.
So I spread the safety mount a bunch but it still won't fit. So I went to the auto parts shop and looked at their replacement mounts and they are also not wide enough to fit. They were also a different brand. The repo mounts will fit but are to low and are made with 1/16 metal compared to the 1/8 on the safety mount. Years ago I changed more mounts than I can count and had no problems with fit. The repo original style mount ( new) looks like it would fail on a Briggs & Stratton.
Dom
Dom
