Coil Wire 427 Boot to Distributor ? - NCRS Discussion Boards
  • Neil C.
    • February 14, 2015
    • 50
    Does the 90 Degree Boot on The Coil wire go on the Coil? and the Straight End of the Wire Go on the Distributor...or Visa Versa...? forgot to take a pix before replacing.. Thanks
  • Ken A.
    • July 31, 1986
    • 929
    Re: Coil Wire 427 Boot to Distributor ?
    ST to Dist
    • Stuart F.
      • August 31, 1996
      • 4676
      I just put one back on a couple hours ago. Straight one on the distributor. As I recall, the coil sticks up just a little higher than the distributor cap. We were priming the carbs for a level check and didn't want the engine to fire, so I pulled the coil wire off the distributor end.
      Stu Fox
