Can someone provide me a schematic diagram for a Penske timing light model 244.2115? This light was sold by Sears. If possible a matching parts list.
Penske timing light (Schematic diagram needed)
Tags: None
- Top
Re: Penske timing light (Schematic diagram needed)
Is this what you want??
http://www.searspartsdirect.com/craf...643/00001.html
I simply went to Sears Parts and typed in your part number.
A lot of used ones on Ebay (for parts or whole)
Larry
EDIT: More info for you. http://forums.aaca.org/topic/68849-timing-light/- Top
Larry
Thanks Larry, I did see that schematic but no parts list included and view not clear.
Rich- Top
I have that timing lite and a sun model also. I don't have the parts list for the sears but the sun I have! There is very little parts to be bought. You can contact Sears&Roebuck on line I believe there is an avenue you can take for parts. If you live in greator Hartford ct area you can borrow mine- Top
The Sears Parts List was next to the schematic drawing I provided. Perhaps a click or two of the mouse or trackball was needed to bring it up. You are correct, there were only a few parts available for this timing light: a few nuts, bolts, and screws, and a few resistors and diodes.I have that timing lite and a sun model also. I don't have the parts list for the sears but the sun I have! There is very little parts to be bought. You can contact Sears&Roebuck on line I believe there is an avenue you can take for parts. If you live in greator Hartford ct area you can borrow mine
The second link I provided had the part number for a compatible flash tube from an Actron light that others have used/substituted.
Ebay is also full of similar lights for a few $……either for parts or for full use.
This is a very nice timing light that I had personally used for over 30 years myself, but switched to an Actron "dial-back" years ago. I gave my old Penske light away to another.
Larry- Top
Just buy a new digital dial back light that also gives rpm-some give dwell also. Not that expensive and you'll find it much more useful than your old broken one.- Top
Larry
I did notice the abbreviated part list but I was hoping that a more detailed list might be available that shows the capacitor detail including the voltage rating. One particular capacitor such as what I believe is labeled C4 across the tube and 100K resistor.
Rich- Top
Frank
Thanks for the offer to use your light but I am a bit to far away. I will do a little searching first to see if I can find the necessary parts to fix the light.
Rich- Top
William
Thanks but,
Before I resort to the new timing light I want to explore possible repair path. I would like to say with the old light it goes well with my old vett and old owner.
Rich- Top
Yes the cap is defective. There is no identification as to capacity or voltage rating on the cap just a part number that I can not reference anywhere. It is a large paper style located in the light handle.
Rich- Top
