67 Speed Warning Label - NCRS Discussion Boards
  • Bill L.
    • April 1, 1985
    • 349
    HI:
    I am trying to discern if there is any rhyme or reason to the speed minder label (Green print) on the back of the 67 speed warning cluster.
    I am under the impression that the labels with the red letters are on standard clusters and the labels with the green letters are on speed-warning equipped cars.
    I have seen a couple of different letter combinations "LE", "LH" and "LA" in green on speed warning equipped cars...just to name a few.
    The part numbers on the tag that I have ("LA") points to a speed warning tach and speedometer----
    Any definitive information on decoding these would be appreciated.
    Regards
    Bill
  • Mike E.
    • February 28, 1975
    • 5134
    Re: 67 Speed Warning Label
    Bill,
    I am no expert here, but I'm guessing the different red lines on tachs would demand different codes. I think the green "LA" indicates low-rpm speed minder, because that's what my 300hp car has.
    • Keith B.
      • September 15, 2014
      • 1575
      The label on my Chevelle speed warning cluster is also in green print. And Mike is correct on the reason of different letters
      • Bill L.
        • April 1, 1985
        • 349
        Thanks Mike! That makes sense ---
        I just acquired a 67 coupe with some interesting options ---
        Head Rests, PW, Shoulder Belts, tint windshield (420JG coded trim tag) speed-warning, 4-speed and a 3.08:1 rear end so the green "LA" on the cluster would fit ....
        A real freeway cruiser!!
        Thanks Again
        Bill
        • R N.
          • May 31, 2002
          • 640
          Originally posted by Bill Lucia (8620)
          HI:
          Regards
          Bill
          Hi Bill,
          My '67 with speed warning and L79 327/350 HP has a green LC label.
