1962 differential fluid capacity - NCRS Discussion Boards
  • Chuck D.
    • February 10, 2013
    • 57
    Anyone know the capacity for a 1962 differential?? I can't seem to find it in my service guide. The Chilton's for this year says 4 pints. I have a 340 hp with a 370:1 posi. I looked the forum info over and saw varying amounts. To put 4 pints in the car requires jacking up the rear. Does this sound correct?? When I pulled the carrier out to rebuild it, the fluid level was over the fill plug level. Don't recall ever seeing this?? I appreciate your feedback.
    Thanks Chuck (58064)
  • Ray C.
    Infrequent User
    • March 1, 1995
    • 18
    Re: 1962 differential fulid capacity
    The 62 Owners Guide says 4 pints, I put 4 pints in mine last week, but it was already on jack stands with axle raised. It did not overflow.
    Ray Culbertson
    • Chuck D.
      • February 10, 2013
      • 57
      Ray, with the car level and 4 pints does the gear oil not run out of the fill hole ?? I'll check my owners guide. Thanks for getting back with me.
      Chuck (58064)
      • Ray C.
        Infrequent User
        • March 1, 1995
        • 18
        Chuck,
        In the past that is the way I filled it, till it ran out the fill hole.
        Ray
        • Chuck D.
          • February 10, 2013
          • 57
          I put 4 pints - per your owner quide suggestion and Chilton's. I forgot how informative the owner's guide is!!
