Horn replacement 66 with A/C ?? - NCRS Discussion Boards
  • Neil C.
    • February 14, 2015
    • 50
    Couldnt find answer in archives so my ?is How to gain acess to Replace Both Horns in a 66 with A/C ....Best access is Hood Removal OR Grill removal? or Both? or neither. Thanks
  • Jim S.
    • March 1, 1986
    • 1392
    Re: Horn replacement 66 with A/C ??
    Neil,
    Either will give you all the access you need . Both is overkill !
    It just boils down to which you feel is easier to do , and or are more comfortable doing .
    Jim
    • Neil C.
      • February 14, 2015
      • 50
      In your Opinion....Which one is Easier????i.e the difference in time OR difficulty between the 2 with Less Chance of hurting any parts on and off???? ThankYou
      • Jim S.
        • March 1, 1986
        • 1392
        Neil,
        I never replaced the horns while the car was together , only reinstalling them during restoration . That's how I remember having plenty of room from above or through the grill slot ,and hence my reply .
        However after further thought on the matter , I think I would get a broom handle and just disconnect the hood support. Then open the hood a lot higher then it normally goes when attached , and go at it that way . Disconnect and reconnect the horns from the front, thru the grille.
        Removing and replacing them from above . Just being ever so careful when sliding the horns past the hood !
        Better minds than mine , most of them here on this forum , will probably chime in tomorrow with a even easier trick neither of us ever thought of !
        Jim
