Dynamat in doors - NCRS Discussion Boards
Dynamat in doors
  • Ed S.
    • August 6, 2014
    • 1377
    Dynamat in doors
    I have to remove the door panels on my 64 convertible to replace worn weather stripping and window felts, and make a few window & lock adjustments. While I have the door panels off is it advisable / worth the effort to install Dynamat to the back side of the door outer skin (fiberglass)?
    I am not looking to improve thermal retention nor am I concerned about "judging" but I am wondering if there will be any benefit to sound deadening. Would appreciate comments from anyone that has applied a Dynamat like product to their doors regarding any noticeable differences / benefits one way or another.
    Ed
  • Mike T.
    • January 1, 1992
    • 568
    Re: Dynamat in doors
    Ed - Last time I had my door panels off the 65 Coupe, I thought it was a good idea to add some Dynamat to the inside of the outer skin of the doors but once the door panel was off, I realized access wasn't the greatest. Obviously with the window down, no access but even with the regulator up, it wasn't great. I had visions of adding a large sheet of Dynamat but wound up using small strips in an effort to cut down on noise/vibration. I did clean the inner skin well with enamel reducer first and the Dynamat stuck to it quite well. I do have side exhaust by the way and had already used Dynamat on the inside surface of the roof when I had to replace the headliner. Even if it helps only a little bit, I still think it was worth it.
    Mike T. - Prescott AZ.
    • Michael G.
      • January 1, 1997
      • 1251
      I did the doors in both my cars.....it's snug but doable and believe it added a measure of quietening outside noises.
      • Mike E.
        • June 24, 2012
        • 920
        I don't know much about the stuff but it sounds interesting. If you have the glass and all the tracks out, like after paint, could you slip a piece down where the glass would normally be?
        Other question does it hold water if it gets wet?
        Mike
        • Terry D.
          • May 31, 1987
          • 2690
          I just did it on my 62 and in my opinion it was worth it! Just my old 2 cents
          • Ed S.
            • August 6, 2014
            • 1377
            Thanks to all for the comments on your experience with Dynamat. Based on your advice I will be installing it in my doors. For Mike, according to the Dynamat website, this stuff is waterproof - the foam does not absorb water and the adhesive that holds it to the surface it is applied to is water proof - just don't cover up any drain holes! For the record, I am not endorsing this product - but for those interested... here is the Dynamat website: http://www.dynamat.com/
            Ed
              When I built my tube-frame Grand Sport replica, I lined the doors with Dynamat - that application was simpler than with a production body, as the Grand Sport didn't use window regulators - it used a simple pull-strap arrangement with seat belt strap and hardware. Made a considerable difference in the feel and sound of the doors, as Dynamat is designed primarily for panel damping.
              • Bruce B.
                • May 31, 1996
                • 2930
                I did the doors in a few C1 cars and my 65.
                Stops lots of noise and if you tap on the outside of the door skin it sounds substantial not tinny.
                I also did the roof on my 65 and it helps also.
                Dynamat Extreme is the way to go.
                Another plus it is also MADE IN THE U.S.A.
