overheating the c 2 crate - NCRS Discussion Boards
  • Francis F.
    • April 1, 1978
    • 420
    now comes the next event,over heating .facts; new 350/330 crate engine,copper radiator flushed,new 180 t stat type"b"(a shorter type) engine was doing ok but now pegs temp ga.,could the t stat be sticking ????or a bad (brand new water pump?) nnt working. Timing 10* @ idle vac disconnected. H E L P
    Francis
  • Harry S.
    • July 31, 2002
    • 5258
    Re: overheating the c 2 crate
    Francis, the quickest, easiest and least expensive step is to remove or replace the the thermostat. If you remove it and the temp is fine then install a Robertshaw 330-180 thermostat. There is a thread in the last week on Robertshaw. Is there an air pocket somewhere?
    Good Luck
    • Keith B.
      • September 15, 2014
      • 1575
      Did you verify the temp gauge.
      • Harry S.
        • July 31, 2002
        • 5258
        Keith, good point. Use an IR gun on the sending unit and see where it is.
        • Keith B.
          • 1575
          No use throwing parts at it when we all know how accurate the mid year temp senders and gauges are
          • Joe R.
            • July 31, 1976
            • 4547
            First, what engine combo did you have in a C-2 that had a copper radiator???
            Don't know of any combination from 63 to 67 with a copper radiator! If it's got one, get rid of it!
            Get an aluminum radiator from Dewitt with an electric fan and end your cooling problems. He sells a nice combination of two fans with a fan shroud that's perfect for your application. He has one for either a BB of SB radiator support.
            JR
            PS. Just remembered the 66-67 BB had a copper radiator. Memory slipping! Still, get rid of it!!!!!!
            • Francis F.
              • April 1, 1978
              • 420
              Harry, you mention air pocket somewhere.How might I relieve /or check for an air pocket??
              Francis
              • Keith B.
                • 1575
                With the engine running and cold open the radiator cap. That will burp the system.
                  • 11608
                  If it was fine and then not, in addition to air also be sure the wire didn't fall off the temp sender and ground itself. If you verify the temp with an IR gauge and it's fine, then think wire/sender/gauge.
                  • Francis F.
                    • April 1, 1978
                    • 420
                    Harry, I removed the t-stat,....but no desired change.Temp still rises to 230* and more.could an air trap actualy stop the flow of anti freeze in the system .do yoy suggest a fix ?
                    Francis
                    • Francis F.
                      • April 1, 1978
                      • 420
                      in the process of an "I R gun",results soon....
                      • Francis F.
                        • April 1, 1978
                        • 420
                        Joe copper is after mkt.,been working satisfactorly with old engine.
                          • 15610
                          Have you verified that the VAC is connected to a full time vacuum source and the VAC meets the Two-Inch-Rule?
                          • Francis F.
                            • April 1, 1978
                            • 420
                            Duke,yes vac I s conn. to full time and vac.can meets the two inch rule.
                            Francis
                            • Francis F.
                              • April 1, 1978
                              • 420
                              At this point I feel there is an air lock,looking in to a fix for such.
                              Francis
