Hi , I have taken the car in to a alignment shop to get an idea of what the present front alignment specs are ( I did not do any work on front) and to set the camber on the rear after the installation new strut rods and cam bolt kits and all bushings.
I did not bring any shims this time as I felt that they could do the rear camber without much c-2 corvette experience, plus I wanted to run the specs past the forum members for suggestions.
*******If you know, looking at my pictures.......how would shims be added or taken away (if possible) to get me to 2*. There is not much bolt left on both right and left a arm. ?
I have attached two photos of my left and front A-arms. Do I have any room left for shims to get the + 2 in castor on the front.?
This is how my car sits now. 1966 L-79 Convertible stock with power steering.
Left Front Right Front
Camber 0.1 + -0.1
Castor +1.1 +1.1
Toe +0.26 +0.26
Total Toe 0.52
Steer Ahead 0.00
Left Rear Right Rear
Camber -0.4 -0.5
Toe +0.5 -0.16
Total Toe +0.33
Thrust Angle+0.33
Pass Side Picture Fender on top side of picture
Driver Side Picture
Camber 0.1 + -0.1
Castor +1.1 +1.1
Toe +0.26 +0.26
Total Toe 0.52
Steer Ahead 0.00
Camber -0.4 -0.5
Toe +0.5 -0.16
Total Toe +0.33
Thrust Angle+0.33
Driver Side Picture
