HI:
Just tested my 4-way blinkers, left and right turn signals both lane change and regular, backup lamps and brake lamps --- everything is working --- EXCEPT the license plate lamp.
I changed the bulb no success. I pulled the lamp fixture out of the car and bench tested it --- it works fine.
I checked the voltage to the ground(black) and power (brown) wire and I get nothing --- that is clearly the problem --- BUT --- EVERYTHING else on that circuit is working ---
Could this be a faulty head lamp switch? I did notice that the panel lamps are also not working --- (The head lamps work fine...) I have to "assume" here that something in the switch is not doing its job to light the license light.
I would appreciate and ideas from those who have had similar problems -- thanks in advance.
Regards
Bill
Regards
Bill
