Over the years I have read all the threads on oil usage for flat tappet cams and don't need anymore arguments. I am more interested in those that own a car with a stock L71 435 HP motor, what oil brand and weight are you actually using? Do you put any ZDDP additives in at oil change? Thanks
Opinion on oil in a L71
Re: Opinion on oil in a L71
My crystal ball says that's exactly what you're going to get.
I doubt that there are enough owners of this or similar engines that have put enough miles on them using current oils to say conclusively one way or the other. The exceptions would be gross neglect of minimum ZDDP requirements, and a caveat of one off failures that would have happened anyway and the ethanol uhh, OIL gets blamed.- Top
As long as the oil has the API rating of CJ-4 or SM(not SN) your'e good to go. SM is the rating GM recommended from the factory in the 60s. I think youll find most diesel 15w-40s(rotella, delo, etc.) have these ratings. There are also small label oils that dont have API ratings that work just as well also but use a SM rated oil and you cant go wrong.- Top
Thanks guys. I have used the diesel oil before. I currently have Valvoline 10w-40 VR1 with a 4 oz. bottle of ZDDP additive in the car. It might only get driven 50 miles a season so I agree it really is not an issue. Thanks again- Top
The SM rating did not appear until about ten years ago. Back in the sixties the rating was MS, based on a different system. Current SM has less ZDDP. Primary category SM should not be used with one exception explained in the next post.As long as the oil has the API rating of CJ-4 or SM(not SN) your'e good to go. SM is the rating GM recommended from the factory in the 60s. I think youll find most diesel 15w-40s(rotella, delo, etc.) have these ratings. There are also small label oils that dont have API ratings that work just as well also but use a SM rated oil and you cant go wrong.
Primary category CJ-4s have a secondary rating of SM or SN. These are okay to use as they have 50 percent more ZDDP than primary category SM. The key is to choose the correct primary category, which is CJ-4.
It's all explained here:
Duke- Top
According to the spec sheet that you can download from the Web, the only available VR-1 multiviscosity ratings are 10W-30 and 20W-50. Both are okay to use in vintage engines as they have sufficient ZDDP based on the P and Zn analyses and no supplemental ZDDP additive is required.
The 10W-30 product only carries the obsolete SH rating. Why? Because the API service category rules state that any SM oil with a low end viscosity rating of 10W or less must comply with the 800 ppm P limitation for SM and SN oils. If the low end viscosity rating is greater than 10W, the P limitation doesn't apply, so the 20W-50 product can be labled SN/SM.
The above is explained in the oil article that is linked in my previous post.
Valvoline VR-1 is the only primary S-category oil I am aware of that has sufficient ZDDP for vintage engines.
Duke- Top
Thanks Duke. I had a senior moment. I had VR1 10w30 in it before I changed it last. It now has Brad Penn 10w-40According to the spec sheet that you can download from the Web, the only available VR-1 multiviscosity ratings are 10W-30 and 20W-50. Both are okay to use in vintage engines as they have sufficient ZDDP based on the P and Zn analyses and no supplemental ZDDP additive is required.
Duke- Top
