I just hooked up a vacuum gauge to my 327/300 and I'm seeing something I'm not sure about. I tee'd into the vacuum hose at the distributor so I would have vacuum advance and I'm reading 10in.hg. I know it's supposed to be closer to 17in. I unhooked the hose from the distributor but did not plug it and got 8in. hg. I then plugged the hose and saw a bit over 17in. I went ahead and adjusted the carb.(Carter AFB) and had readings of 18in. hg. I went through the whole procedure again and the readings were the same with vacuum hooked up to the distributor. My question is: should adjustments with a vacuum gauge be performed with the vacuum line pulled and plugged at the distributor or do I have a problem? I looked in the archieves and couldn't find any info pertaining to my particular problem so any advice would be appreciated. Thank you in advance.
Bill
Bill
