Is this a correct original 091 coil for 63?? - NCRS Discussion Boards
  • John F.
    • January 1, 2000
    • 155
    Hey Fellas,
    Can anyone tell me if this is an original and correct 091 engine coil for a 63? Also, any idea on how to test it when it's out of the car?
    thanks so much!
  • David S.
    • December 1, 1982
    • 310
    Re: Is this a correct original 091 coil for 63??
    I vote yes but you are missing a few small pieces for wire connection.
    • Bruce B.
      • May 31, 1996
      • 2930
      I understand there was a time in 1963 where the 091 coils did not have the 2 holes at the 2 connection posts.
      Anyone have info on that?
      • John D.
        • December 1, 1979
        • 5507
        Bruce, The earlier version of the 091 has the two holes for the retainers. So then why would DR discontinue the holes for a time in '63?
        That's so new info Bruce. Now to see what the guru's say about that. John
        John, One way to test the coil is to use the specs in the shop manual. THen get a good digital Ohms tester.
        For example the specs in the Corvette Servicing Guide for the 097 have:Primary Resistance-Ohms 1.02-1.13
        My coil reads 1.1
        Secondary Resistance. DR = 8000-10500. My coil reads 9000 plus.
        Now I realize there is more to testing a coil than this is a start. Another good way is to try in on the car. JD
        • Dave S.
          • August 31, 1992
          • 2918
          My coil reads 1.1
          The "shoulders" definitely are indicative of a 63 (late 091). I think it's correct.
          • Rick A.
            • July 31, 2002
            • 2147
            Agree, it "appears" to be correct for late-1963 application, but missing some of the "hardware" as mentioned
            Rick Aleshire
            2016 Ebony C7R Z06 "ROSA"
            • Bruce B.
              • May 31, 1996
              • 2930
              My coil reads 1.1
              John,
              Thanks for all the info.
              Hope all is well for you.
              Will I see you at Carlisle this year?
              Bruce B
              • John D.
                • December 1, 1979
                • 5507
                Bruce, God willing I will be at Carlisle in 50 plus days. Whew!!!! Time goes so fast. John
