Wiring Diagram Question - NCRS Discussion Boards
  • Thomas F.
    • November 11, 2008
    • 204
    1969 Corvette. I am having trouble tracing certain wires through the bulkhead connector on the wiring diagram. It says "top", "view A", and "view B", but this is really confusing me. I sometimes trace a wire to the bulkhead connector, but cannot figure where it comes out on the other side. I am sure this is simple but I need some help. I understand that sometimes these wires change color at this connector. Anyway if anyone can help me out I would really appreciate it. Thanks.
  • Donald O.
    • May 31, 1990
    • 1580
    Re: Wiring Diagram Question
    Which wires are you have a problem tracing, which connector?
    DonO
    • Thomas F.
      • November 11, 2008
      • 204
      Using a wiring diagram I am having trouble understanding how to trace any wire from the fuse box side (interior of car) to the two connectors on the other side (engine side). The wiring diagram shows both but I am having trouble understanding how they relate to each other. I understand it might be difficult to explain in text maybe I just need to sit down with someone and let them explain it to me.
      • Joe R.
        • May 31, 2006
        • 1822
        Can you post a picture of at least a portion of the schematic where you are having trouble with the diagram?
        Joe
        • Stephen L.
          • May 31, 1984
          • 3148
          If you visualize the plug diagrams as being on 2 adjacent pages of an open book, when you close the book this would be how the plugs go together. Another way to explain is the plugs are "mirror images" of each other..... Sometimes the plug "hole" positions are numbered and you match the numbers.........
