Anyone close to vin 194677S109108(Jan. 27, 1967 birthday) could you please tell me your carb date.
need carb date help please
Re: need carb date help please
Paul, you may want to tell us what exact motor you have in your car. A 390 smog car having a 3815 carb will be a rare carb that's not pulled off the rack with regularity, whereas a 3810 that's applicable on all 300 and 350hp non smog cars were much more used. The 6 month window for judging is one thing, but actuality/reality is another. Let us know what you got and maybe we can assist. By the way, welcome aboard!!!!!!!!! ARA- Top
Paul,
Which engine do you have? I can't speak to 67's specifically, but in general the small block dates are closer together. I have a 66 L72 (427 / 425), the carb is dated pretty close (maybe two weeks prior) to the engine assy date (which is probably more important than the car assy date in this case).
Joe- Top
The carb date has no relevance to the engine assembly date since it was installed at the car assembly plant and not the engine assembly plant.Paul,
Joe- Top
I think I've read somewhere that Holley carbs were produced in large batches so the dates are kind of all over the place.
Is there any real data out that supports that?
To my knowledge anything between 6 months prior and a few days before the build date would be acceptable.
Mike- Top
