1968 Power Steering Problem - NCRS Discussion Boards
  • Terry B.
    • August 31, 1999
    • 607
    I have a Power Steering problem with my 1968, 427 L-36. When the unit is cold, I have power steering but as the unit warms up the power steering assist goes away. As long as the car is moving, I do not notice the problem but turning the wheel getting the car back into the garage, there is no power assist. The system use to make a slight noise when I turned the wheel going back into the garage after it was warmed up, but now that does not happen. Of the 3 major components of the system, the pump, power control valve and steering cylinder, what do you think is the problem or should I replace all 3 components? The entire system, except for the hoses, is at least 15 years old and could even be original. Thank you for your help.
    Terry Buchanan
    Webmaster / Secretary - Heart of Ohio Chapter www.ncrs.org/hoo
    Corvettes Owned:
    1977 Coupe
    1968 Convertible 427/390 (L-36) Chapter Top Flight 2007, Regional Top Flight 2010, National Top Flight 2011
    2003 Electron Blue Coupe
    2019 Torch Red Grand Sport Coupe
  • Jim S.
    • August 31, 2001
    • 730
    Re: 1968 Power Steering Problem
    Is your problem when you turn in either direction? If it only happens in one direction it cannot be a pump problem.
    If the problem is in both directions, and is strictly temperature related, my first inclination would be the pump. You should hear some pump noise when you reach near full lock since the pump should be going into pressure relief. Don't hold it in full lock for more than a few seconds.
    Again, no noise from the pump would most likely lead me to the pump as the culprit.
    Jim
