T-Top sealer.Any recommendations? - NCRS Discussion Boards
  • Scott M.
    • April 30, 2002
    • 128
    Any thoughts on a suitable material to replace the gray gunk under the T -Top trim pieces? I was going to either use the standard 3M Windo-Weld Ribbon Sealer part 08612 or see if the loacal plumbing supply house had some plumbers's putty to use. I would have no issue using the 3M Ribbon Sealer except the stuff that the original stuff that is already in there seems a little dryer, more dense and less pliable that the 3M stuff. In the back of my head I'm worrying about coming back out to my car on a hot day and seeing stuff oozing out all over the interior.
    • 6940
    Re: T-Top sealer.Any recommendations?
    Scott, 3M strip chalk works ,its non hardening and won't drip from heat, I also heard that that Home Depot or Lowes sells a gray colored chalk. maybe someone else will chime in on this.
    • Pete B.
      • February 22, 2007
      • 318
      Grey caulk on a roll is what I used! No problems here in the Arizona desert.
      Pete Bergmann
      2005 - 2013 C6 National Teamleader
        • 3415
        Hi,
        I believe the gray colored caulk that Lowes, etc. offers is under the Mortite/Frost King brand name. It's generally in the same area as the door/widow weatherstriping and seals.
        It seems very similar to the 3M strip caulk, but perhaps not quite as sticky.
        • Jim T.
          • March 1, 1993
          • 5351
          Scott I used 3M strip caulk when I replaced the front piece and the area you have shown in pictures. I did this on my 1970 in 1989 and still have no problems with the 3M strip caulk used.
