I'm in the process of redoing brakes. This is my first experience with discs. I have measured the runout on the rear discs. One side has a difference of .017 from low to high and other has .015. See the attached photo for actual values around the circumference of both discs. Is this an acceptable variance? If not should I shim rotor or have rotors turned? If so, where do you get shims? The rotors are not new but are well over minimum thickness and in good shape.
Second photo is the setup used to measure.
