Having trouble with both cold and hot starts. Cold start requires pumping the throttle and cranking for 3 to 4 seconds. Hot start requires throttle to the floor and 5 seconds of cranking then the engine runs rough for about 30 seconds. The car has the original 340HP engine with all of the correct external parts on it and runs fairly well in normal driving. It was rebuilt by one of the previous owners some time before 1999. I have done the following to try to improve the start problem:
-Did a compression check. All cylinders 160 psi to 180psi.
-I rebuilt the AFB 1 year ago it has the correct jets and metering rods. I just took the top off last week and reset the floats.
-I reset the valve lash to .008 I and .015 E (duke Williams) I have no way to verify that the cam is a 097.
-The vacuum can is a B28 and is working correctly. Initial advance is set at 14 deg BTDC with the vacuum plugged.
-I currently have an early Petronix electronic ignition in the distributor. The distributor is in good shape with no shaft play issues. My next step will be to reinstall the breaker points to see if that helps.
- Choke works and is set correctly when cold the RPM is 1200 to 1300.
- The car has no overheating problems as I installed a new Dewitts restoration aluminum radiator
-The only other issue that I will be addressing is at WOT the engine starts missing about 4500 RPM. BTW the rear end has 4:11 gears.
Any help will be greatly appreciated,
Jeff
Jeff
