Question on tank sticker was answered.
Tank Sticker Number ?
Re: Tank Sticker Number ?
Key codes. The vin sequence should be there too.
To add, they are two separate codes. One for each key, alpha numeric, four digits each.- Top
James, There are some more knowledgeable members here, that I hope will chime in, many are at the National Convention at the moment. But I would say more than 9999 with the use of letters and numbers.Originally posted by James Baird (36056)Kevin, do you know if there are typical key codes, as in there are 25 common ones I can try to match, or are there 9999 possibilities? I can make out some of the digits, but not all. I'll try to attach another pic.
These codes make it possible to cut a new key and perhaps not a good idea to post online, your call.
Keep trying to read it from the back side, you might get close. There's a member Pete Lindahl, he knows this VERY well! Try to reach out to him for some additional help.
Good luck- Top
