A long short story and three questions:
I recently had to replace the drive shaft seal in the high pressure pump on the FI unit (a 7380) which I think was done successfully with parts and advice from John DeGregory. In the process I took the entire unit off the car so that I could replace the spill valve cover o-ring and the fuel supply and return line o-rings with viton parts. I also flushed the nozzles with carb cleaner and replaced the nozzle and nozzle block gaskets. In the process I found that one of the plenum leg gaskets had previously been "supplemented" with silicone and the plenum lid gasket had also. I got it all back together with new gaskets and without breaking anything and it now runs better, I'm guessing due to having eliminated some vacuum leaks and cleaning the nozzles. Previously I could not get it to stay running on initial start without racing the engine and generally had to start it twice. At idle it surged. Now it will start without touching the throttle (cold) and will idle at fairly constant rpm. So today I put a vacuum gauge in the line from the plenum to the vacuum advance, started the car, and brought it to about 170 degrees temp (can't get much hotter without driving it a long while). Idle was about 1500 (I think high due to the improved vacuum) which I reduced to 1100 (I know the book calls for 850 or so but I seem to remember an article from Duke Williams which recommended the 1100). So with engine hot and at 1100 the vacuum was 14 in hg. I thought it would be lower. Does this seen to be right for a FI unit?? What should I expect??
Secondly, there is a screw on the top of the air meter which is described as idle fuel in the shop manual but looking at the diagram is really a control of supplemental vacuum from the plenum to the main fuel meter diaphram at idle since the throttle is mostly closed. The book says start it at 1.5 turns out at 850 rpm and then adjust for best idle. Mine is out 2.5 turns. Turning it in caused the idle to surge. Turning it out does nothing which I think means it is already out of way (no restriction). If this makes sense, does the fact that I need full plenum vacuum at idle indicate an issue?? The only one I can come up with is that the main diaphram is "stiff" and I need a little more help to flex it. I have a new one but have never changed it.
Third, and really a different topic, on top the air meter on the right next to the plenum (looking from the driver side) is a set screw/plug which looks to be about 7/16 diameter slotted....just an aluminum slotted plug...does anyone know it's function??
Thanks for any responses I might get.
