I have a petcock that has aluminum threads on the part that screws into the radiator and metal on the winged ends, is the correct petcock suppose to be all aluminum? during my last judging this was brought to my attention, that its should be all aluminum and not magnetic.
63 radiator petcock question
Re: 63 radiator petcock question
Ed,
If 63 is like later years then from the factory they had an aluminum plug that was screwed into the hole, very similar to the drain plugs in the side of the block. In service this was then usually changed to the petcock. So, in theory any petcock would not be correct.
If you need an all-aluminum one, Paragon reproduces it.
https://www.paragoncorvette.com/p-35...-assembly.aspx
PatrickVice-Chairman (West), Michigan Chapter NCRS
Ed,
The judges are correct in that a 63 should have an all aluminum petcock. They were supplied with the radiator from Harrison. Even the replacement radiators were supplied with an aluminum petcock.
JR- Top
There you go. Aluminum petcock in 63, but your 72 would have been a plug.Vice-Chairman (West), Michigan Chapter NCRS
I saw one not long ago on a C3. As you might expect they're not common this many years later.Vice-Chairman (West), Michigan Chapter NCRS
Thanks everyone for your reply's, I will try and see if DeWitt's has the all aluminum petcock when I am in Carlisle next month.New England chapter member, 63 Convert. 327/340- Chapter/Regional/national Top Flight, 72 coupe- chapter and regional Top Flight.- Top
- Top
I wanted to bring this thread back to the front so someone could see a post on this discussion.New England chapter member, 63 Convert. 327/340- Chapter/Regional/national Top Flight, 72 coupe- chapter and regional Top Flight.- Top
