I have started reinstalling the chrome and stainless steel header pieces that are part of the halo surround. I have a few questions about it.
1. The original screws that I removed from the corner header moldings were mostly reusable, however it has been quite a while since I had removed the pieces and...Iv'e slept a few times since then. I still have the screws with the countersunk heads that go in from the back side and the black screws that go in from the windshield side. When I look at the screw kit that some of the vendors sell, there are 4 screws with machine threads shown (2 per side). Do these go into the ends of the corner moldings? Because I only have a spot to put one screw there and being a machine screw thread, I figured it would have been installed somewhere besides through the side of the windshield frame like a common sheetmetal screw.
2. The areas where the stainless t-trim meets the corner moldings. When I removed the pieces originally, I noticed there was a yellowish sealer there where the flat surfaces overlap. I have the gray strip caulk and the black 3M windo-weld to use, but this looked like it more resembled the yellow weatherstripping adhesive. What should be used in that area?
