Sticky 66 antenna - NCRS Discussion Boards
Sticky 66 antenna
  • Marc K.
    Infrequent User
    • July 6, 2011
    • 18
    Sticky 66 antenna
    My original antenna was only going up two of the four sections. I lubed the mast and pulled it while going up and now it goes up three sections. The last top section won't go up. My car has been kept out of bad weather and the antenna appears to be in great shape looking at it from underneath. Does my antenna need a rebuild or is this something that can easily be fixed?
    Does the muffler need to be removed in order to remove the antenna assembly?
  • Greg T.
    • January 1, 2004
    • 136
    Re: Sticky 66 antenna
    The last solid section is almost always frozen. The cable is rusted and stuck in the last tubular section. It will need to be
    disassembled. You don't have to remove the muffler to remove the antenna. See below.
