A question for Duke, Joe, Stuart and the other ignition timing experts: What do you think of the aftermarket variable vacuum advance units that are available? One brand is Accel:
http://shop.accel-ignition.com/ignit...points-v8.html
I installed one years ago in a 72 Chevelle 350 with good results. I was able to dial in a vacuum advance curve that worked well for the engine. The link has a document showing how the curve varies as the can is adjusted.
I know this isn't for judging, but it worked well for me in the past. It may be a good alternative to searching for those hard to find canisters; plus it enables fine tuning of the vacuum advance.
