Re: 1970 LS-7 engine
Patrick-------
The information I presented came from an April, 1970 edition of the P&A catalog. I am confident that it accurately reflects the scheduled parts content of the LS-7 or HD (454) as of that time. It's also true that later editions of the P&A catalogs drop most of the reference to parts for HD (454). That's to be expected as the HD (454) or LS-7 was never used in PRODUCTION. The LS-7 may very well have "morphed" into something other than it was originally intended as time went on. However, the only thing I am referring to is what the LS-7 was ORIGINALLY intended to be. Whatever it morphed into is totally irrelevant from a PRODUCTION perspective.
You noted that the hood drawing from the AIM is dated May, 1970. In the revision box it states "redrawn and redesigned". I'm quite confident that the original drawing included the high rise, L-88 style hood. This is all moot because neither design ever made it to PRODUCTION. Nevertheless, the original intention for the LS-7 was for an L-88 type hood and that would only have made sense if the original intention was for the engine to use a high rise manifold.
The GM #3965774 engine assembly was a SERVICE only engine assembly. While the part number dates from late 1969, I agree that the engine did not enter SERVICE availability until about 1973 or, possibly, later. It's also very possible that the specifications (and parts content) of the 3965774 engine assembly was revised over the 1969-73 period. That would be unusual, but it's possible. Cast iron open chamber heads were available as early as late 1969 using GM casting #3964291.
I'll give you an example of an error in the AMA specifications: the 1968 and 1969 AMA specifications for Corvettes specified that engines coupled with automatic transmissions used CCS exhaust emission control. However, all 1968 and 1969 Corvettes, regardless of transmission, were equipped with AIR exhaust emission control, including L-88 and ZL-1.
A couple of additional points:
1) The GM #3965774 engine assembly very closely met the specifications of the ORIGINAL LS-7 configuration---it had 12.25:1 compression, the 3959180 camshaft, a 5140 crankshaft, open chamber heads, and a Corvette oil pan. All of these attributes are in line with the earlier L-88/ZL-1. The only real difference was the use of cast iron rather than aluminum heads. The engine was not supplied with an intake manifold;
2) The engine that you describe that the LS-7 morphed into is, essentially, an engine which already had its own designation and that designation was LS-6.
Patrick-------
