Some of the comments in the recently revived string on LS-6 Corvettes seemed to suggest that the advertised but never sold 1970 LS-7 Corvette was a 454 version of an L-88 or ZL-1. I think it was really something much milder-- a 454 substitute for the street high performance 69 L-71/L89.
First of all, it was advertised and appeared in early Corvette Brochures and in the Chevy dealer Sales Album. The "heavy duty" L-88 and ZL-1 engines for racing were never advertised this way. The brochures advertised that it had aluminum heads and was rated at 460hp. The AMA and other specs at the GM heritage center fill in a lot of the other details. First of all it had a streetable 11.25:1 compression ratio, probably increased from the 427 L-71 to take advantage of the aluminum heads reduced tendency to ping on marginal gas. Unlike the L-88, it had a distributor with a vacuum advance (and a very aggressive centrifugal advance). It used a Holley carb with the same size venturis as the LT-1 (hence a 780 cfm carb not the 850 cfm L-88 carb). The oil pan to air cleaner height was the same as the LS-5. Therefore it would use the low LS-6 manifold and fit under the regular LT-1/LS-5 hood. However, unlike the L-89 it would use the open chamber aluminum heads with 1.88" exhaust valves rather than 1.84" exhaust valves in the closed chamber aluminum heads of the L-89. The most surprising fact in the AMA specs was the cam. Instead of the L-78, L-72, L-71, LS-6 street mechanical cam with .5197 gross lift, intake and exhaust, it used a variation with the same .5197 intake lift but a greater .5498 gross exhaust lift. It is also surprising that this slightly improved street mechanical cam never made it to the over-the-counter speed parts sold by GM.
So, it appears that the differences between the LS-6 for the 70 Chevelle and the LS-7 intended for the 70 Corvette were that the LS-7 would use open chamber aluminum heads with 11.25 CR while the LS-6 used cast iron closed chamber heads with 11.00 CR and that the LS-7 would use a cam with more exhaust lift. Both were hot street engines. Unfortunately the LS-7 11.25 pistons and the hotter street cam never made to the parts department.
However, the parts department is responsible for the idea that the LS-7 would have been a heavy duty racing engine. From at least the early 70's GM sold a 454 HD engine under part number 3965774 (pad suffix XCH). It had 12:1 CR, ZL-1 cam and a cast iron version of the open chamber ZL-1/L-88 heads. The parts dept also sold under part number 3981820 a 454 with 11:1 CR and cast iron closed chamber heads identified as 1970 LS-6.
Some time around 1980 GM began selling a 454 with the 70 LS-6 short block (closed chamber 11:1 CR pistons and LS-6 cam) but with the cast iron open chamber heads. This combination had a compression ratio of 10.2:1. It was similar to the 71 Corvette LS-6 but it had iron heads and higher compression pistons. It was sold under part number 366250 and had a pad suffix of XAA.
Until about 1986, the 12:1 CR 454 was simply called the 454 HD. However, in the 1986 HD parts list the 454 HD (3965774) is now called an LS-7 and the hybrid 10.2 CR open chamber 454 (366250) is now called an LS-6. These designations are purely parts catalog names and neither the over-the-counter LS-6 or LS-7 are the same as the 1970 LS-7 or LS-6 or even the 1971 LS-6 intended or installed in real cars. No wonder the LS-7 is such a misunderstood chapter in Corvette history.
