Upper/lower Control Arm bushings questions - NCRS Discussion Boards
    Re: Upper/lower Control Arm bushings questions
    Originally posted by Gary Schisler (21316)
    Joe,
    Are you saying that the embossing is on the rubber bushing itself? Thank you for the GM part numbers, too.
    Mark,
    The car rides remarkably well and handles as well as I expect it would. My original assessment was based on the appearance of the outer portion of the bushing and not on ride, noise, or any other discernible quality. I will have to think about this for a while.
    thank you all,
    Gary
    Gary-------
    Yes, the manufacturers' names "Clevite" and "Harris" appear embossed on the rubber portion of the bushing.
    • Gary S.
      • July 31, 1992
      • 1628
      WWell, in that case, I won't be seeing much there, considering their condition.
      • Jim T.
        • March 1, 1993
        • 5351
        #18
        Gary since you may visit Bairs for some work, check with them for type of bushings they use when they rebuild the arms. Might save you work time to let Bairs do all the needed work on your control arms since you might be able to schedule a one day service to go and return the same day with work completed to enjoy your Corvette.
