Horsepower ratings
Re: Horsepower ratings
If you set up the spark advance map to something like the 365/375 HP 327s, you will think it's an entirely different engine, and it's easy to do. Max centrifugal is 22 @ 2300, which is fine. Just set total WOT advance at 38-40 at something over 2300. Convert to full time vacuum advance and install a B28 VAC in place of the OE 201 15, then go through the idle speed/mixture adjustment procedure for pre-emission engines. The improvement in power across the entire rev range and lower fuel consumption will be obvious.As I'm reading this very informative thread...I can't help chuckling a little. I have a '72 and while it's a really nice car...Let's face it...It ain't no road burner. I once toyed with the idea of having the original engine rebuilt to 1970 specs...but, I already have way more invested in this car than my estate will ever get for it...and besides, I way too old to worry about "burning up the road."
All the whys and wherefores are in my San Diego national convention tuning seminar, which is on the Web.
Of course, someone may have already improved the spark advance map in the past, so the first thing to do is test with a dial back timing light to set what is actually is.
Duke- Top
Mike, where did have your car "dynoed"? We each live in north Texas, and I'm interested in having that done.Mark Edmondson
Dallas, Texas
Texas Chapter
1993 Coupe, 40th Anniversary, 6-speed, PEG 1, FX3, CD, Bronze Top- Top
Typically STD, "standard temperature/pressure", is used to correct lab dyno observed results and "SAE correction" is used to correct chassis dyno results. Unless this context is known, it's an apples to oranges comparison. Can you state what type of correction, if any, was used for your reported results?- Top
Go to www.dynojet.com You can search for dynos via zip code also download the free "Winpep" software. Develop a test plan (send me an email if you want a template) and discuss it with the shop before you commit. Determine how you can take the individual test file with you. They are very small. If the computer has email, that will work, or whatever I/O device it has...CD, thumb drive, etc. Now you load those test file onto your computer and use the Winpep software to manipulate the data, show different graphs, use different correction factors, etc. Also, please start the runs at no more than 1500. For some reason dyno operators don't like to start this low, but it will do more harm, and this data is needed to understand the full across the range performance characteristics. Also agree on the maximum test RPM. Don't let the guy stop the test just because the power appears to have peaked.- Top
New 1.pdfTypically STD, "standard temperature/pressure", is used to correct lab dyno observed results and "SAE correction" is used to correct chassis dyno results. Unless this context is known, it's an apples to oranges comparison. Can you state what type of correction, if any, was used for your reported results?
New 2.pdf
New 3.pdfAttached Files- Top
Thanks for posting the data. The torque curve is tough to see, but it looks like it makes 90 percent of peak at 2000, which is excellent and better than I thought a L-46 would do. Massaging the heads would have added about ten percent more power in the upper rev range. The lab dyno test exceeded the advertised gross torque rating, so I assume it was done with headers. Is that correct?- Top
Yes, the lab dyno was done with headers and the heads were massaged.Thanks for posting the data. The torque curve is tough to see, but it looks like it makes 90 percent of peak at 2000, which is excellent and better than I thought a L-46 would do. Massaging the heads would have added about ten percent more power in the upper rev range. The lab dyno test exceeded the advertised gross torque rating, so I assume it was done with headers. Is that correct?- Top
The 396 rated at 375 hp in a chevelle was another one that was under rated. NHRA figured out it was essentially the same as the Corvette 396 rated at 425 hp and used the 425 number for putting these Chevelles in a class.- Top
I always come away form threads on this subject a little confuse. Do I have this right; The "net" horsepower rating used for '72 on are at the flywheel with stock induction system exhausts, engine mounted accessories in place, but NOT rear wheel horsepower??- Top
No OEM uses rear wheel horsepower, back then or now.I always come away form threads on this subject a little confuse. Do I have this right; The "net" horsepower rating used for '72 on are at the flywheel with stock induction system exhausts, engine mounted accessories in place, but NOT rear wheel horsepower??- Top
So, Michael,
on a new car that says has such and such horsepower, that's rear wheel horsepower, like it's calculated with car in it's entirety tied down and run on a chassis dyno? Not just the engine on a stand but with stock exhaust and all accessories installed??- Top
