This is for a '71 LS-5 4 speed car. Supposed to be a numbers matching car.
Legit Stamping?
Re: Legit Stamping?
Do the numbers match? 'Numbers matching' does not equal original factory-installed engine in many people's vocabulary.
Impossible to give a 'possibly original' answer with paint covering the pad surface and filling the stamped characters.- Top
2007 Z06, Lemans Blue
Newsletter Editor, Delaware Valley Chapter- Top
Re: Legit Stamping?
They match the frame, transmission, and VIN tag. This is a basket case car. The last time it sold had an automatic console in it. But the "CPH" on the block tells me manual. And it now is selling with a manual which the casting date and VIN on the transmission correctly.- Top
Re: Legit Stamping?
If the engine is not in the car (which it appears it's not), now would be the easiest time to get a cloth and some lacquer thinner and remove the paint from the stamped pad. THEN, take another picture and submit for the guru's to look at.Leif
Top Flight 2017 Lone Star Regional- Top
