Re: Big-block aluminum intakes with stock hood clearance for C3s?
I just went out and measured the Holley Street Dominator, and as you can see, you could easily have a machine shop shave 1/2" to 3/4" off the carb mounting flange. This will give you the extra room required, but now you're talking machining costs, and by the time you have this done, you could probably buy an original L36 intake for the same amount! That, plus the "unknowns" of shaving the flange is probably not worth it.
Ed
Ed
). So I'm thinking about the ZZ454 which has an updated 4-bolt block with a hydraulic roller cam and aluminum, open chamber, oval port heads. With a spread-bore Q-Jet and tall gears I'm hoping this combo will meet my needs but have a lot more kick than the standard LS4 (or even LS5 given the roller cam and weight savings). The ZZ454's intake won't fit under the hood, so that's why I'm asking about low-profile aluminum intakes. I guess I could install an iron LS5 intake, but that just seems strange on top of aluminum heads.
