Any body making these shields? Thanks in advance.
1963 rear strut rod heat shield
Re: 1963 rear strut rod heat shield
Here's the heat shields on a January 1964 car.
.Jan64strutbrktADBLarge.jpg- Top
In Appreciation of John Hinckley- Top
Was wondering how far into 64 production one would expect to see these shields?
Dan1964 Red FI Coupe, DUNTOV '09
Drove the 64 over 5000 miles to three Regionals and the San Jose National, one dust storm and 40 lbs of bugs!- Top
I seem to see more cars without these little square welded on sheet metal than one's that do. Was this hit and miss or do they just break off? I'm assuming these were welded on after the cams and strut rods were assembled. Yes, no?- Top
That's a no. They were spot welded to the camber support assembly.
JR- Top
The deletion of the shield from the strut rod bracket was not accompanied by a change of part number. Apparently, it was changed simply by a revision to the specs for the part.In Appreciation of John Hinckley- Top
So only '63 and perhaps early '64 brackets were manufactured with the shields? When the shields were deleted, was that accompanied by a re-routing of the exhaust pipes to get the heat away from the camber rod bushings?- Top
