A sunny day , out for a drive, car died like it ran out of gas, no gas in fuel filter bowl. There was gas in the car but added more and still no fuel being pumped to the carbs. Towed back to shop and removed fuel line after pump to see if pumping, with no evidence that it was. Bought new Airtech 9797 fuel pump and installed. Cranked the engine and it ran for about one minuet, long enough to see if vacuum for wiper was pumping. Pump seemed to have vacuum (bottom half of pump) but not pump fuel (top half). Hard for me to believe I am having the same problem with two pumps.
Has anyone encountered a similar problem or an idea of were to turn to next?
By the way , why does the top portion of the fuel pump on the 1954 have an off set? It moves the glass fuel filter very close to the block. Is this is correct?
Thanks, Ted
Thanks, Ted
