In short, depending on TIRE SIZE, will an Amerian mag wheel- 7 x 15, work on the rears of a 1964 Coupe without damaging the fender's inside glass lip? The fronts would have 6 x 15 wheels. Thank you , Jack J.
Wheel acceptability
Re: Wheel acceptability
Jack,
Width should not be a problem. Offset is where you could run into an issue.Leif
Top Flight 2017 Lone Star Regional- Top
Jack,
I just installed a set of Diamond Back Michelin Defender redlines on the '67...size 215/70R15. Look and perform flawlessly.Leif
I have American Mag 15X7s all around with 205X70R15 DB redline radials on my '64, no issues at all.Attached FilesBig Tanks In the High Mountains of New Mexico- Top
Jack,
Be sure to check the DOT numbers on those tires.Leif
Jack -
You do NOT want those fat 255/60's on the front and much narrower 215/70's on the rear - aside from looking really weird, you'll have handling problems. Also, the front tires are WAY mis-matched to the 15 x 6 wheels; 255/60 tires are designed for 7"-9" rims per B.F. Goodrich, and will look "pinched" and will have "crowned" tread surface on 6" rims.- Top
