Help, What would cause a Ballast Resistor to run very hot??
Back ground--It has 12.3 volts going into it and approximately 9 volts and 4 amps after the resistor.
The Resistor measures 1.7 ohm resistance.
I have tried different Resistors and coils with the same result.
The points (2) and condenser are new as is all of the car wiring.
The Battery is also new from Restoration Battery.
The car seems to run fine but the Resistor does get hot enough to smoke!
Any ideas would be greatly appreciated.
Dave
Dave
