The battery in a C3 is so far from the engine compartment that the power lead from the timing light won't reach the battery. Someone in a post said attach the power lead to the 12 volt source on the alternator. I assume the 12 volt lead on the alternator is the post under the black rubber boot in the attached picture. Am I correct. Is it ok to power the timing light from the alternator?
Timing light power source
Re: Timing light power source
Yes, the connection on the back of the alternator will work, so will the power lead (large diameter red wire) on the horn relay. So long as you don't short either connection to ground there will be no damage to the components from this use.The battery in a C3 is so far from the engine compartment that the power lead from the timing light won't reach the battery. Someone in a post said attach the power lead to the 12 volt source on the alternator. I assume the 12 volt lead on the alternator is the post under the black rubber boot in the attached picture. Am I correct. Is it ok to power the timing light from the alternator?Terry- Top
Greg-------
I always use the power connection at the horn relay. Very convenient and easily accessed.In Appreciation of John Hinckley- Top
i have spent about six months restoring the engine compartment, removed and replaced engine, rebuilt front suspension and more. I am embarrassed to admit that I don't know where the horn relay is. The car has dual horns. Can you point me to it?- Top
Nowhere near the horns.
Left (driver's) inner fender, ahead and left of your brake master cylinder.
Image Googled and linked below. Not the same year exactly as yours, but you get the idea.
2012-11-30_005015_69_corvette_fusible_linkk.jpgVice-Chairman (West), Michigan Chapter NCRS
I use a small 12v motorcycle battery on the floor next to the car.The battery in a C3 is so far from the engine compartment that the power lead from the timing light won't reach the battery. Someone in a post said attach the power lead to the 12 volt source on the alternator. I assume the 12 volt lead on the alternator is the post under the black rubber boot in the attached picture. Am I correct. Is it ok to power the timing light from the alternator?
Works great.- Top
On a 75 it is not on the inner fender. The AIM 12G sheet 1 shows it by the fuse block. Can't really tell if it is inside or outside but I don't remember seeing it. Now that everything is back together the power brake booster, evaporative fuel canister, wash bottle, clutch linkage and brake lines make the fuse panel almost inaccessible. I know I have a relay because horns work. Must be inside.- Top
Leif
Top Flight 2017 Lone Star Regional- Top
That's exactly how I fried the inductance cable on my dial-back Actron the other day. I repaired it but I think the pickup overheated and now it's junk. Called Actron and they don't sell parts. I hate Asian items like this as nobody can fix things anymore as the parts aren't available.
Looking for another one locally and not even my AAuto, AZone, or Napa stock them. I might have to resort to Amazon and wait for delivery.
- Top
