Temperture Senders-Thermostats - NCRS Discussion Boards
  • Richard S.
    • April 1, 2003
    • 288
    I am looking for a reliable source for a new temperature sender and thermostat for my 63-340HP car. Prefer units that are tested if they are available.
  • Frank D.
    • December 27, 2007
    • 2703
    Re: Temperture Senders-Thermostats
    Many just buy 3-4 of the Wells TU-5 senders and use the one that is most accurate....its always a crap shoot. Putting a resistor in line to get the temp right at one temperature is done but the change isn't linear and errors will creep on either side of the selected temperature.
    • Richard S.
      • April 1, 2003
      • 288
      Thank for the information. Do you happen to know what the nominal resistance of the sender unit is over the normal car temperature range?
      • Frank D.
        • December 27, 2007
        • 2703
        You could call their support hotline:
        You can also peruse the chart in the attachment!
        • Richard S.
          • April 1, 2003
          • 288
          Thank you I will give a ring
          • John D.
            • December 1, 1979
            • 5507
            Richard, I buy Stant 180 degree thermostats from NAPA. The brownish gasket comes from Car Quest. If A car owner isn't having his car judged then I use the GM gasket. The black one that is the worlds best gasket but no good for our judging. John
