What's the recommended, or at least minimum clearance between the fiberglass floorboard and exhaust pipes on a C3?
I'm asking because I have a severe radiant heat problem along the bottom of the console next to the inside edge of each seat bottom. Once the car is at operating temperature, the carpet gets too hot to touch in this area. This heat is radiating from the exhaust pipes which are between 1/4" and 1/2" away from the fiberglass along this same area. I'm specifically talking about the section of exhaust from behind the frame cross-member to the rear of the of the floorboard where the inside edge of the seats are near. Talk about seat warmers!
I'm hoping rerouting the pipes with more clearance will help. But how much clearance should there be? I found no reference in AIM.
Also, who has wrapped exhaust pipes to reduce radiant cockpit heat? Results?
I believe the original pipes were double-walled- maybe to reduce heat? Since this type of pipe is apparently no longer available (I've asked a few shops and the parts houses), I'm wondering if wrap might be the next best thing.
