65 Tunnel insulation glue pattern - NCRS Discussion Boards
  • Scott P.
    • April 30, 1992
    • 178
    So I'm removing a tunnel insulation blanket from a 65 coupe. As you see from the pictures the glue flowed upward or the body was upside down when the glue was applied. So can glue defy gravity and flow upward or was the body upside down when the glue was sprayed on. Pretty sure this insulation had never been removed or reapplied. Thanks Scott
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11302
    Re: 65 Tunnel insulation glue pattern
    Scott, They probably brushed or sprayed the glue on the floor upside down before it was bonded to the other panels. I saw the same "drip"evidence lately on the '67 I'm restoring which was never separated from the chassis until I got to it. Here are a few pics I just shot.
    What you suspect is probably correct, upside down, but to optimize production I'd guess many pieces wee installed to the panels before bonding to other panels, in some cases upside down. Much like the chassis assembly, upside down so gravity aided the workers handling the heavy items.
    Rich
      [ATTACH=CONFIG]63742[/ATTACH] [ATTACH=CONFIG]63741[/ATTACH][ATTACH=CONFIG]63743[/ATTACH]
      Scott -
      That insulator was installed as part of the underbody subassembly in the basement below the Body Shop, after the bend-over retainers were riveted in place; the underbody was inverted at that time. That's why the glue runs "uphill".
      • John S.
        • May 4, 2008
        • 424
        The man has spoken. I say that with great respect towards John H. as he was there and without him there would be many many questions unanswered here. Thank you John and all the other contributors to this forum that help out all the time.
        John Seeley
        67 Black/Teal
        300 hp 3 speed coupe
        65 Maroon/Black
        35k mile Fuelie coupe
        • Richard M.
          Super Moderator
          • August 31, 1988
          • 11302
          Thanks John, I was hoping you were going to see this one. Great info.
          Rich
          • Scott P.
            • April 30, 1992
            • 178
            Well shucks, I was hoping my glue ran uphill. Scott
