57 Oil Filter Cannister - NCRS Discussion Boards
  • Greg K.
    • September 30, 1985
    • 32
    Would someone tell me how to remove the stud from the canister? There seems to be a retainer of some sort under the washer inside the canister. Can't tell how that was configured or installed. Any info, pics would be greatly appreciated.
    Greg
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11302
    Re: 57 Oil Filter Cannister
    Greg, When I replace the copper washer and rubber gasket using the repair kit, they say to use a sharp chisel to trim the 2 ridges on the long bolt holding the cup. If you push the cup down a bit you'll see them.
    In the kit they include a press-on retainer ring to hold the cup after assembly.
    The page you were looking for was not found or has been deleted. Search Corvette Parts by year or category instead.
    Rich
    • Greg K.
      • 32
      Thanks Rich. That's a help and start.
      • Greg K.
        • 32
        I just checked with Zip and they don't have a repair kit for a 57. My retainer looks more like a snap ring that was crimped in one spot than a washer. Guess I'll need to figure how to get that snap ring off.
        • Gene M.
          • April 1, 1985
          • 4232
          Greg,
          Once you remove the long bolt, turn a shallow groove (in same position of the staked area) to accept a retaining ring for reassembly. A retaining ring can be assembled using the straight prong tips on the retaining ring pliers while pushing down against the spring. Do not use an E ring or snap ring as they are not captive and could dislodge. Retaining rings are obtainable from True Arc, hardware supply store, and online. I just resurfaced the soft copper washer for reuse.
          • Greg K.
            • 32
            Does anyone know how to get the long bolt out? There appears to be a thin band that is crimped holding the bell shaped retainer in place.
            • Eric E.
              • November 1, 1998
              • 254
              Like Gene said, the thin retainer is just a staked part of the bolt surface that holds the spring plate. I have read where a few have said to just give the threaded end of the bolt (with a misc nut on the end) a whack with a hammer and it will drive the bolt out through the plate. The pictures that I have seen seem to show where that method tears up the edge of the plate where it contacts the stakes. I recommend the shearing off stakes method by retaining the bolt head in a soft jaw vice, place a screwdriver against the stakes and tap them to shear them off. Then cut the retaining groove and add a snap ring.
              if you want to message me, I have an article that covers the resto process.
              • Bruce B.
                • May 31, 1996
                • 2930
                My experience on a number of canisters is to hold the bolt head, reach in the canister hold and push the retainer and and turn it. The retainer will index to a point where it slips over the bump on the bolt and comes off.
                No hammer necessary.
                Bruce B
                • Greg K.
                  • 32
                  That would be sweet, but my retainer doesn't have any slots of index points to do as you suggest. Would be nice though. Looks like I have to either press the staked piece of the bolt back up against the bolt or shear the staked piece off. Thanks for your idea.
