Need Recommendation on some Company to Anodize Original Rockers - NCRS Discussion Boards
  • Joe R.
    • July 31, 1976
    • 4547
    I need a recommendation on someone to Anodize Rocker Moldings.
    Just don't want to use repos as they don't fit or look good on the ends.
    Thanks everyone,
    JR
  • John D.
    • December 1, 1979
    • 5507
    Re: Need Recommendation on some Company to Anodize Original Rockers
    Joe, Andy Cannizzo has a plater that anodizes the rockers. I assume you have his number. If not. 732-583-5378
    Or call Jorjorian. JD
    • Jim D.
      • 2882
      JR, I was going to use this guy to redo my 65 rockers until I found some NOS ones ( I wish I would have sent him mine to redo, the NOS ones were not like the originals). He comes highly recommended. http://www.trimrestoration.com/ Very few do the correct bright dip anodizing prior to the clear.
      • Frank D.
        • December 27, 2007
        • 2703
        Andy is excellent and does the whole process - he has my '63 shifter console for restoration as I write...
        • Stuart F.
          • August 31, 1996
          • 4676
          I still have my originals from my 63. I put NOS panels on back in about 92, just to spruce it up a little. My old ones are still good having just a few pits and road tar, etc., and the black painting in the slots is worn thin in spots. Can the re-anodizing be done including the clean up and painting? What are we talking about for expense and time? I'm happy with my NOS panels, but they too are starting to show age and road grime. So, if I were to fix them up, I wonder if it would be worth it to just re-do my originals while I continue to drive.
          Stu Fox
          • Joe R.
            • July 31, 1976
            • 4547
            Thanks guys. A couple of those recommended are not doing anodizing anymore and one was not on my list of references.
            Anyone else care to help!
            JR
            • Frank D.
              • December 27, 2007
              • 2703
              Andy is certainly anodizing center consoles - I talked to him within the last 48 hours...can't say if he still does the rockers (I have an original pair that need redone too) but I would think so.
              He is the best, but not cheap....
              • Tom B.
                • March 1, 2002
                • 140
                King of Trim in Ca. does a great job with mldgs. I have had many done there.
                • Jim S.
                  • March 1, 1986
                  • 1392
                  Tom,
                  What is the average cost for a pair ?
                  Jim
                  • Arland D.
                    Moderator
                    • July 31, 1980
                    • 415
                    Joe,
                    I have used McNichols in Michigan http://www.mcnicholsanodizing.com/ They do very good work and from my personal experience, they are 1/4 the cost King of Trim in California charges. They are very familiar with automotive anodizing needs and the last time I had them do some work, they finished the job, sent it back to me, and said "if you like the work, send a check because they don't take credit cards". Hard to find someone so good at what they do and will let you inspect the finished work before you pay for it!
                    • Joe R.
                      • July 31, 1976
                      • 4547
                      Arland,
                      Thanks for the info! sounds good and I'll contact them in the AM.
                      Joe
                      • Scott P.
                        • April 30, 1992
                        • 178
                        Joe, call these folks.
                        United Plating Works
                        Plating Service
                        Address: 4118 N Mingo Rd, Tulsa, OK 74116
                        Phone918) 835-4683
                        • Joe R.
                          • July 31, 1976
                          • 4547
                          Thanks Scott! I have all the stuff for two 63 Roadsters and one 64 already polished and ready for anodizing! Would be worth the drive to Tulsa. Will call in AM.
                          JR
                          • Jim S.
                            • March 1, 1986
                            • 1392
                            Joe ,
                            Since I am right behind you in sending my rockers out , would you mind sharing what you found out , price quotes etc. and who you decided to go with? Either here or by pm.
                            Jim
