Does the 58 have a four hole flat bracket mounted to the manifold or does the U bracket bolt directly to the manifold? The car is fuel injected. This is a very early car with right side hood support
1958 generator mount
Tags: None
- Top
Re: 1958 generator mount
The U bracket should bolt directly to the manifold, there is a heat shield for it. Be careful the fan belt clears the bottom radiator hose. Chevrolet used a mickey mouse fix, they pulled the Lower radiator hose back against the fuel line with a radiator clamp for fan belt clearance. Very early 58s had the RH motor mount ball peened for fan belt clearance, later 58s had a depression made in the mount.
Dan1964 Red FI Coupe, DUNTOV '09
Drove the 64 over 5000 miles to three Regionals and the San Jose National, one dust storm and 40 lbs of bugs!- Top
FYI a document and more info in these threads....
https://www.forums.ncrs.org/showthre...729#post730729
The pdf I wrote has some info relative to the '58 FI bracket in Addendum A
Post #10 in this thread a while ago has Dan's awesome document enclosed which may help.
https://www.forums.ncrs.org/showthre...986#post729986
Rich- Top
