I just had a scary ride home from a local vette together this evening. About a mile into my trip home my headlights started cutting completely out.😱 The first time they came right back on, then each time after they stayed off a little longer. Then they stayed on the rest of my trip home,thankfully. It happened with just the low beams on, and I put on the high beams and they all went out.
Could changing the lamps have anything to do with this? When I bought the car it had halogen lamps in it and I drove it home At night from West Chester Pa. to my home over 200 miles on the Pa. Turnpike with no headlight problems at all. Recently I just purchased two brand new OEM Guide High Beams and two used OEM Guide Low beams and installed them in the car. A couple of weeks ago they went out once and came back on and stayed on, unlike what I experienced tonight. I also installed a new headlight switch this spring because my headlights weren't coming up and I had to use the bypass.
Any help with what I should check to see what is causing this would be greatly appreciated.
Thank you
Thank you
I appreciate all the suggestions.
