The original door post weatherstrips on a '59 I've been tinkering with had their original retainers still attached. I had the posts chromed but put the rubber pieces in a bag some time ago.
After looking closely When I took the retainers off and saw the backsides, I was surprised. Not totally surprised as I've seen many original bolts, brackets and other hardware items also with a dichromate finish. (yellow plating over clear)
P9140301.jpgP9140303.jpgP9140305.jpgP9140309.jpgP9140310.jpgP9140312.jpgP9140313.jpgP9140314.jpgP9160330.jpg
I media blasted them, which was hard to do without losing them in the cabinet
, and decided to make them "yellow cad" again. Note the numbers stamped on the backside of the lowers which are not interchangeable. Likely a stamping code for left and right.
Not exactly like they were originally, but close.
I cut the loop wires from the old pieces and refinished and spliced them in the rubber. The retainers have little hooks that catch the wires inside the rubber. I cut the top retainer from it's reinforcements and pushed them into the rubber and attached. All use 6-32 screws.
P9160334.jpgP9160336.jpgP9160337.jpgP9160338.jpgP9160351.jpgP9160352.jpgP9160353.jpgP9160354.jpgP9160355.jpgP9160356.jpgP9160357.jpgP9160358.jpgP9160360.jpg
After test fitting I glued the rubbers to the posts and finished assembly of the retainers.
Done.....
PS. It appears i used the wrong type 6-32 screws. I'll need to get flat head screws. makes sense to keep a lower profile against the window posts.
, and decided to make them "yellow cad" again. Note the numbers stamped on the backside of the lowers which are not interchangeable. Likely a stamping code for left and right.P9160331.jpgP9160332.jpgP9160333.jpg
I cut the loop wires from the old pieces and refinished and spliced them in the rubber. The retainers have little hooks that catch the wires inside the rubber. I cut the top retainer from it's reinforcements and pushed them into the rubber and attached. All use 6-32 screws.P9160334.jpgP9160336.jpgP9160337.jpgP9160338.jpgP9160351.jpgP9160352.jpgP9160353.jpgP9160354.jpgP9160355.jpgP9160356.jpgP9160357.jpgP9160358.jpgP9160360.jpg
Done.....
