For my 66 Chevelle 396 engine board .30 over with a stock GM 454/425 crate replacement roller cam(GMPP 454 cam 211/230), stock 702 heads, stock 396/360 Holley carb and a stock GM 396/325 points distributor. on acceleration its fine. but once around 2K RPM it wants to have a hiccup up or miss. I reset the dwell on the points to 30. the timing is set to the service manual. I am thinking my vacuum advance is not correct or working correctly. I was at a parts store and they can get me a standard motor unit for all 3 engines. the V375 is listed for the 396/375 solid lifter engine, and the V280 is listed for the mid rage 396/360. The vacuum can I have now is stamped 357
when I un-connect and plug the vacuum line from the carb the hiccup goes away and the car accelerates better.
