This related to a basically bare frame. I have installed the front suspension and started install the rear suspension. I installed the rebuilt trailing arms, differential, and leaf springs.
My question is, can I install the strut rods or should I wait for more weight on the chassis?
With the springs installed and very little weight on them, they push the trailing arms down to a point where the strut rod mounts are very much out of alignment with the strut rod mount points on the bracket under the differential. I will need to use a ratchet strap or something similar to pull the trailing arm up so that I can get both ends of the strut rods in place.
My concern is the torque this will be placing on the strut rod bushing and that it could and likely will sit this way for a few months.
Would it be better to wait until I have the engine, trans, and body back on the car, or am I worrying about nothing?
Don
Don
Is it too late for you to unbolt the spring ends, install the strut rods, and re-bolt the leaf spring?
