65 tail light socket to housing ground - NCRS Discussion Boards
  • Bill W.
    • March 1, 1980
    • 2000
    I removed my 65 tail light sockets from the housings years ago to have them rechromed . I now need to reattach them , what is the best way to make sure there is a ground between the socket and the chromed housing ?
  • James W.
    • December 1, 1990
    • 2640
    Re: 65 tail light socket to housing ground
    The ground from the socket will be via the wiring harness ground wire if I remember correctly.
    James West
    • Bill W.
      • March 1, 1980
      • 2000
      Yes James the wire grounds to the housing mounting stud but the socket needs to have a good ground to the housing .
      • Alan D.
        • January 1, 2005
        • 2027
        That's it for the ground. If you desire to add one I would run a wire from socket to stud. Pretty sure you can hide it behind glass so judge will not see.
